TwinTurbo.NET: Nissan 300ZX forum - Re: Did you perform an OHM test on the injector or
Subject Re: Did you perform an OHM test on the injector or
Posted by DEcosse on November 05, 2014 at 4:30 AM
  This message has been viewed 302 times.
In Reply To Did you perform an OHM test on the injector or posted by John (MD) on November 04, 2014 at 05:38 PM
Message It's not the injector - I replaced it and can hear it clicking if I use screwdriver as a 'stethoscope'
I believe it's the PTU at this point - the resistance readings across the circuit 5 transistors are MUCH lower than all the others; although it appeared to fire at atmosphere, there may not be enough energy to produce spark under compression.
Currently awaiting PTU to arrive .............
