TwinTurbo.NET: Nissan 300ZX forum - Remove the filler plug first in case the drain plug is >>>
Subject Remove the filler plug first in case the drain plug is >>>
Posted by ZUL8TR on November 03, 2014 at 3:57 PM
  This message has been viewed 490 times.
In Reply To What size wrench is that transmission drain plug square?? posted by jgbatlantaZ on November 02, 2014 at 12:22 PM
Message stuck, if the drain plug opens and the filler plug is jammed you will not be able to add gear oil back in. Do not over tighten the plugs. I use a 1/2" x 18" breaker bar to remove them.
ZUL8TR in Orlando,FL
