TwinTurbo.NET: Nissan 300ZX forum - Sounds like a pre-load problem. Pre-load must be set off car
Subject Sounds like a pre-load problem. Pre-load must be set off car
Posted by flashstar on November 03, 2014 at 1:42 AM
  This message has been viewed 374 times.
In Reply To coilover problems posted by SeanSmith91 on November 01, 2014 at 11:43 PM
Message Set the springs so that they are lightly held in place by the collars with the strut bodies off the car. Then, only adjust the bottom cup for height.
When the coilovers are installed, your rubber suspension bushings will put pressure on the springs. If you set pre-load to zero with the coilovers in your car, you will lose strut travel and height.
Also, make sure to loosen and re-tighten your rubber chassis bushings with your Z on the ground when you've reached your final ride height.
