TwinTurbo.NET: Nissan 300ZX forum - The Zed is VERY Sensitive to Throttle Plate Setting at Idle
Subject The Zed is VERY Sensitive to Throttle Plate Setting at Idle
Posted by Cjw3 on November 02, 2014 at 8:47 AM
  This message has been viewed 491 times.
In Reply To 2 is better but like you said dyno tunes just use one posted by LivinTheDream on November 01, 2014 at 12:29 PM
Message To have any chance of passing a Tailpipe Smog, the T-Plates need to be set to allow the same mixture/Airflow each Bank.
If you only have One WB, you have no idea what the other side is doing at Idle.. Unless you want to extrapolate Signals from the Narrowbands..
If you have a Turbo, you need to balance the operation of the waste-gates to make sure you are getting the same air flow on each side, you do that by checking mixtures each side while in boost.
Cj
