TwinTurbo.NET: Nissan 300ZX forum - 2+2 Auto to 5 speed swap. How many miles on
ttz'in (NorCal)
on November 01, 2014 at 2:10 PM
Redline MT-90 installed. less than 5miles of use with it.
posted by LivinTheDream
on November 01, 2014 at 12:27 PM
trans and trans mount ? Did you use the auto, or manual cross member support bracket ?
4th gear grind?
LivinTheDream
10:35:27 10/31/14
Probably the synchro.....
FrozTTy
12:16:17 10/31/14
fast n furious or nice n slow it still does it
LivinTheDream
12:05:42 11/01/14
Same upshift issue some years ago. Downshift from 5th
ttz'in (NorCal)
14:13:10 10/31/14
I used to get the same gear grinding when
SammybTT(TN)
22:39:15 10/31/14
LivinTheDream
12:27:35 11/01/14
2+2 Auto to 5 speed swap. How many miles on -
ttz'in (NorCal)
14:10:28 11/01/14
manual cross member bracket. mount has 2 years
LivinTheDream
19:19:01 11/01/14
I would think that's the smart way to go.
ttz'in (NorCal)
21:21:53 11/01/14
do you think the shifter mounting hardware is different
LivinTheDream
18:52:53 11/02/14
Not familar with RHD specs at all. (n/m)
ttz'in (NorCal)
11:10:51 11/03/14
Got offered one for $280 thats assured to be working fine.
LivinTheDream
13:33:31 11/03/14
TT Trans ? How many miles on it ? Assuming your
ttz'in (NorCal)
03:22:54 11/04/14
Pretty sure its a tt. unsure how many miles are on it.
LivinTheDream
08:12:26 11/04/14
You'll find out quickly
-Grimm-
10:20:20 11/04/14
Per Grimm's post. Use flywheel to test. NA 5 speed
ttz'in (NorCal)
12:56:37 11/04/14
Its a TT trans. unknown miles. BUT...
LivinTheDream
17:36:02 11/04/14
The operative word "assured" Caveat Emptor. (n/m)
ZUL8TR
03:35:09 11/04/14
Do you have the 2 piece or 1 piece drive shaft? (n/m)
ZUL8TR
03:38:35 11/04/14
2pc. tt back half with an mt na front half welded together.
LivinTheDream
08:14:33 11/04/14
Cant a trans from a skyline gts-t work? change bellhousing?? (n/m)
LivinTheDream
13:06:45 11/04/14
