TwinTurbo.NET: Nissan 300ZX forum - 4th gear grind?
Subject 4th gear grind?
Posted by LivinTheDream on October 31, 2014 at 10:35 AM
  This message has been viewed 702 times.
Message So my tranny grinds when I try to shift into 4th but only at higher rpm. It will be a bit stubborn and if muscle it to shift it will grind. Is this a tranny issue or clutch adjustment issue? I figured If it was an adjustment issue it would be with all gears. But if the gears are not in motion it shouldn't grind when i shift either. So I'm not sure what to think.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
