TwinTurbo.NET: Nissan 300ZX forum - Could be as simple as the line. Could be as complicated
Subject Could be as simple as the line. Could be as complicated
Posted by Frldy_Z on October 31, 2014 at 3:12 AM
  This message has been viewed 297 times.
In Reply To Check it out posted by -Grimm- on October 30, 2014 at 10:10 AM
Message as major broken parts in the tranny. Sounds like the slave/master cylinder went out. Get under car and inspect the line first. If it looks wet then there is your problem. Just make sure that it is not "wet" from another leaking fluid. I have actually tested this by putting air compressor (make sure air psi is not above specific rate) on slave cylinder and found out that it was the master because everything else worked perfect.
