TwinTurbo.NET: Nissan 300ZX forum - Fork was my first thought as well..
ttz'in (NorCal)
on October 30, 2014 at 12:44 PM
Re: Clutch problem or?
posted by ttz'in (NorCal)
on October 29, 2014 at 07:05 PM
Especially when there is no pressure from the slave, seems pretty loose.
Bleed system, if you get the pedal back, and there are no leaks and again goes soft. Think MC.
Clutch problem or?
ZroadsTTer
18:08:32 10/29/14
Happens fairly often unfortunately....can be either a bad
jzack
18:27:46 10/29/14
Should have added - regardless of the issue, if not sure
jzack
18:31:06 10/29/14
ttz'in (NorCal)
19:05:55 10/29/14
Fork was my first thought as well.. -
ttz'in (NorCal)
12:44:08 10/30/14
Could be clutch fork pivot......
zx299
01:19:24 10/30/14
I hope its not this one. (n/m)
ZroadsTTer
02:28:40 10/30/14
Check it out
-Grimm-
10:10:49 10/30/14
Could be as simple as the line. Could be as complicated
Frldy_Z
03:12:54 10/31/14
