TwinTurbo.NET: Nissan 300ZX forum - Just tested the replacement TPS. Here are my readings
Subject Just tested the replacement TPS. Here are my readings
Posted by XTZ on October 28, 2014 at 4:58 PM
  This message has been viewed 425 times.
In Reply To Re: Car will not idle!!!!! TPS?? posted by NIVO88T on October 28, 2014 at 08:48 AM
Message Pin A should be 0v
My result: A= 6.2mv
Pin B should be 5v
My result: B= 5.1v
Pin C (black wire) to pin E (red wire) should be about 9,000 ohms.
My result: C to E= 9.25k ohm
Pin C (black wire) to pin D (white wire) should be 1,000 ohms.
My result: C to D= 0.888k ohm
Connecting to the white wire on the back of the TPS side, The voltage should be between 0.4v and 0.5v.
My result: = 0.419v with a max of 3.920v at full open throttle.
I will be posting a video soon as well.
