TwinTurbo.NET: Nissan 300ZX forum - Re: Na/TT Swap
Subject Re: Na/TT Swap
Posted by ThisIsSparTTa on October 28, 2014 at 11:26 AM
  This message has been viewed 431 times.
In Reply To Na/TT Swap posted by danvan on October 28, 2014 at 12:10 AM
Message Short block is very similar with slightly different squirters, and oil tree is slightly different. Crank is the same. Pistons/bore are the same to my knowledge. Pretty sure the oil line for the passenger turbo is tapped but blocked on the NA block.
The big difference is in the heads and the compression they make.
When my friend was getting IPP to do a big TT power build, he had no problem working with the NA short-block but didn't want to work with NA heads for various reasons.
