TwinTurbo.NET: Nissan 300ZX forum - The FSM keeps pointing to fuel pressure regulator. It
Subject The FSM keeps pointing to fuel pressure regulator. It
Posted by ZTicket(Dallas) on October 28, 2014 at 9:56 AM
  This message has been viewed 464 times.
In Reply To when you turn the key, the pump only runs for a few seconds posted by aliaZ on October 27, 2014 at 08:22 AM
Message never goes as far as pointing to FPCU, or Fuel Pump, much less, in-tank fuel pump damper. BUT, symptoms are: it's pressurizing with the initial key on, I hear the pump...then it loses the pressure when the pump sound goes away. The FSM says the fuel pressure regulator is to be replaced if the pressure doesn't stay at 37psi. Same answer for symptoms of loss of power under cruise throttle, loss of power while turning. My car does both of these things. Since the fuel pressure regulator is the easiest to access/least expensive, I'm going to replace the part and see if the car still fails.
