TwinTurbo.NET: Nissan 300ZX forum - Re: Car will not idle!!!!! TPS??
Subject Re: Car will not idle!!!!! TPS??
Posted by NIVO88T on October 28, 2014 at 8:48 AM
  This message has been viewed 903 times.
In Reply To Car will not idle!!!!! TPS?? posted by XTZ on October 26, 2014 at 07:15 PM
Message Pin C to Pin E I get 9550 ohms on one car and 7890 ohms on another.
Pin C to Pin E on the wiki will vary depending on your Throttle body adjustments and TPS adjustments. so you may see from 800 ohms to 1.1k ohms at the idle position and about 7800 - 9200 ohms up top.
The max voltage I can get out of my TPS is 4.64 volts but usually with the stopper bolts for proper throttle plate alignment you see about the 3.8 - 4.0 volts. I wanted to see what the max voltage out was. It will never reach 5 volts on my cars.
What is you minimum? .44V or .46V? if so you have a 1990 NA? so you might have the bolt up just a bit and if it's still factory then 3.8V might be you actual minimum since new.
You can adjust it in just a bit so at max throttle you see the 4V. all the way in you might get 4.51-4.64 volts depending on your tps adjustment.
Here is Thumper300ZX image showing the stop bolt, some cars have an actual bump and not the stop bolt.
