TwinTurbo.NET: Nissan 300ZX forum - the NA is higher compression. but it can be done.
Subject the NA is higher compression. but it can be done.
Posted by LivinTheDream on October 28, 2014 at 6:41 AM
  This message has been viewed 398 times.
In Reply To Na/TT Swap posted by danvan on October 28, 2014 at 12:10 AM
Message The internals of the na are different. I'm not sure of all the details but the oil squirters are different for sure. I wonder why they made um different?
Pistons are different as the na is 9.5:1 compression I think.
The heads are different in terms of the porting and how they flow.
The oil pump is different: A actually just a spring that's in it to raise pressure on a tt.
I think you would have to get an oil cooler for the na but thats easy.
Check post from coverttt or somethin like that. He has 2 na motors with snails on them.
I know tuning is the main concern. The oil pump may not be an issue.
"torque gets you off the line...& hp gets you over the line." -
TTKeeper
