TwinTurbo.NET: Nissan 300ZX forum - Good point. I also thought of a partial HL situation via
ttz'in (NorCal)
on October 26, 2014 at 2:04 PM
the dragging starter might be a clue
posted by aliaZ
on October 26, 2014 at 01:54 PM
a bad injector, or O ring letting fuel get past, but no mention of smoke or smell when starting.
The Success of Failure. The Z finally failed when I
ZTicket(Dallas)
12:09:50 10/26/14
aliaZ
13:54:11 10/26/14
Where is the controller located? (n/m)
JMartz
14:03:32 10/26/14
Behind headlight adjustment tools (n/m)
ttz'in (NorCal)
15:09:46 10/26/14
Good point. I also thought of a partial HL situation via -
ttz'in (NorCal)
14:04:17 10/26/14
Did a pressure test of lower intake manifold before
ZTicket(Dallas)
14:21:08 10/26/14
Or is the FPCU breaking down and cutting power ?
ttz'in (NorCal)
15:08:39 10/26/14
My "guess" is, it never makes it out of the tank.
ZTicket(Dallas)
06:31:32 10/27/14
it has to make it out of the tank if you are seeing it on
aliaZ
08:24:40 10/27/14
when you turn the key, the pump only runs for a few seconds
aliaZ
08:22:49 10/27/14
The FSM keeps pointing to fuel pressure regulator. It
ZTicket(Dallas)
09:56:04 10/28/14
I'll check the oil for signs/smell of fuel. I didn't
ZTicket(Dallas)
14:09:02 10/26/14
Pulled the dipstick, smelled oily. A faint hint of gasoline
ZTicket(Dallas)
06:34:53 10/27/14
the next time it happens, I'd check the vacuum lines from
aliaZ
08:25:59 10/27/14
This could help the "fuel in the intake" theory. If
ZTicket(Dallas)
09:00:12 10/27/14
interesting clue
aliaZ
08:31:05 10/27/14
This was also mentioned by TriniTT a few days ago. I
ZTicket(Dallas)
09:06:14 10/27/14
FPCU access via plastic cover for headlight aim tools.
ttz'in (NorCal)
12:25:06 10/27/14
