TwinTurbo.NET: Nissan 300ZX forum - Werent you having problems with your 98+ tranny?
ZXoltan
on October 26, 2014 at 10:32 AM
I'm using this
posted by aquariuscsm
on October 25, 2014 at 06:55 PM
or was that someone else? If it was you, how did you ever resolve those issues?
Whining transmission, 1st through third..
MaxxAction
10:42:39 10/22/14
Bearing? (n/m)
JMartz
13:52:25 10/22/14
No noise in neutral...
-Grimm-
16:55:06 10/22/14
Re: No noise in neutral...
MaxxAction
17:39:29 10/22/14
Sounds like Cluster Gear Bearings (n/m)
Cjw3
21:01:53 10/22/14
I was thinking input shaft bearing? (n/m)
-Grimm-
10:08:44 10/23/14
Re: I was thinking input shaft bearing?
MaxxAction
11:47:14 10/23/14
Yes.
-Grimm-
15:25:45 10/23/14
It is a roll of the Dice. Must open and See (n/m)
Cjw3
20:09:33 10/23/14
what brand, type, GL# gear oil is in there? (n/m)
ZUL8TR
05:00:02 10/23/14
Re: what brand, type, GL# gear oil is in there?
MaxxAction
06:02:07 10/23/14
Be advised Mobil 1 synthetic is a GL5 gear lube not >>>
ZUL8TR
12:29:55 10/23/14
^ Correct GL4 as ZUL8TR states. Haven't used RP, but
ttz'in (NorCal)
13:02:38 10/23/14
Re: ^ Correct GL4 as ZUL8TR states. Haven't used RP, but
MaxxAction
13:11:10 10/23/14
Cool, let us know results. (n/m)
ttz'in (NorCal)
13:29:09 10/23/14
Hope it works for you but the RL 75w-140 NS is a GL5 >>>
ZUL8TR
04:36:27 10/24/14
BIG + on the Royal Purple
BarryGZX
20:02:52 10/23/14
Interesting on the added Synchromax since that is RP>>
ZUL8TR
04:19:30 10/24/14
Re: Interesting on the added Synchromax since that is RP>>
BarryGZX
19:19:23 10/24/14
I'm using this
aquariuscsm
18:55:18 10/25/14
Werent you having problems with your 98+ tranny? -
ZXoltan
10:32:55 10/26/14
I had mine replaced under warranty (n/m)
aliaZ
09:52:02 10/27/14
Re: Whining transmission, 1st through third..
MaxxAction
21:04:39 10/26/14
