TwinTurbo.NET: Nissan 300ZX forum - Replace the bent valves
Subject Replace the bent valves
Posted by DAYTONAZ on October 24, 2014 at 10:51 AM
  This message has been viewed 437 times.
In Reply To Bent Valves Replacement Question posted by macwizz77 on October 23, 2014 at 11:01 PM
Message The NA heads are 30P castings vs the 40P castings for the TT. It has been shown that the castings are similar but the exhaust valves are different between the TT and NA in that the TT heads use inconel exhaust valves.
Since you have removed both heads to inspect the valves you should have the heads serviced. Checked for flatness and valves checked for play and seal. Essentially you should get a valve job done. The guides will not have to be replaced unless they are out of spec. The heads will come back clean, valves lapped for a nice tight seal, and new valves stem seals at the very least.
