TwinTurbo.NET: Nissan 300ZX forum - Whining transmission, 1st through third..
Subject Whining transmission, 1st through third..
Posted by MaxxAction on October 22, 2014 at 10:42 AM
  This message has been viewed 398 times.
Message Hey gurus and gals...
I have a whine (sounds like a supercharger) in my transmission that is only present from first through third gear. It makes no noise when in neutral (besides gear lash from solid hub clutch) and is a little more prevalent when the transmission is good and hot.
This is a low mileage NA transmission mated to my LS swap. I have read about the input shaft bearing causing something similar, but some say that noise will be present all the time.
Anyone ever experienced this issue before? What was the fix? Thanks.
