TwinTurbo.NET: Nissan 300ZX forum - Re: Given your compression numbers and recent rebuild
Subject Re: Given your compression numbers and recent rebuild
Posted by Barthur on October 21, 2014 at 7:44 PM
  This message has been viewed 285 times.
In Reply To Given your compression numbers and recent rebuild posted by JMartz on October 21, 2014 at 02:46 PM
Message As you said, there is no obvious loss elsewhere. The engine remains clean with no sign of leakage on it. If the head or head gasket is cracked then it is not leaking to the outside. At a minimum it looks like I will need to pull the heads. Worse case is a lower end tear down.
