TwinTurbo.NET: Nissan 300ZX forum - Usually if replacing or relocating the det sensor
Subject Usually if replacing or relocating the det sensor
Posted by TriniTT on October 21, 2014 at 4:50 PM
  This message has been viewed 313 times.
In Reply To Update on code 34 posted by ukrdon2006 on October 21, 2014 at 11:04 AM
Message and you still have a consistent code 34, it's likely because you have detonation. Have you run a compression test or checked the spark plugs? That would be my next recommendation. Also your issue with the engine stalling could be due to improper iacv adjustment or even a vacuum leak. You can find the proper adjustment procedures via faq or search.
