TwinTurbo.NET: Nissan 300ZX forum - yes, it has good fuel pressure (n/m)
johnny_z
on October 17, 2014 at 9:58 PM
When you turn the key to the run postion without cranking it
posted by njz
on October 17, 2014 at 09:29 PM
90 tt swap no start
johnny_z
20:51:43 10/17/14
njz
21:29:44 10/17/14
yes, it has good fuel pressure (n/m) -
johnny_z
21:58:25 10/17/14
just to clarify, everything is working except injectors.
johnny_z
22:33:21 10/17/14
Manually rotate CAS to verify injectors clicking ? (n/m)
ttz'in (NorCal)
22:42:22 10/17/14
no, there is no voltage to the injectors-should be constant
johnny_z
22:50:14 10/17/14
These might help. BTW, new efi harness ?
ttz'in (NorCal)
22:57:46 10/17/14
Re: no, there is no voltage to the injectors-should be constant
Sportzcoop
23:33:59 10/17/14
use the fsm wiring dia. to check continuity on the wires
LivinTheDream
07:49:32 10/18/14
