TwinTurbo.NET: Nissan 300ZX forum - Check diagnostics for codes then
BarryGZX
on October 17, 2014 at 6:39 PM
Need Help. Problem:Engine quits while driving. It will
posted by ZTicket(Dallas)
on October 17, 2014 at 12:23 PM
install fuel press gauge to watch as you drive
ZTicket(Dallas)
12:23:48 10/17/14
Any Codes ? Try Search ? (n/m)
ttz'in (NorCal)
15:00:30 10/17/14
Check diagnostics for codes then -
BarryGZX
18:39:22 10/17/14
like they said run codes.... i bet o2 sensor(s) (n/m)
FrozTTy
13:42:05 10/19/14
o2 sensors won't cause the engine to shut down (n/m)
aliaZ
15:02:36 10/19/14
Sure will!
FrozTTy
10:15:20 10/20/14
ok
aliaZ
12:27:02 10/20/14
It was a stock NA, are you implying something
FrozTTy
12:52:49 10/20/14
can you hear the fuel pump?
aliaZ
15:06:25 10/19/14
Setting up a pressure gauge to monitor pressure before
ZTicket(Dallas)
13:22:23 10/20/14
ALSO..CAS and PTU AND O2s are all less that 5000mi. (n/m)
ZTicket(Dallas)
13:25:23 10/20/14
UPDATE: Hooked Fuel pressure gauge & diagnostics tool
ZTicket(Dallas)
18:16:27 10/20/14
maybe your fuel pump controller is going bad? (n/m)
aliaZ
20:33:25 10/20/14
