TwinTurbo.NET: Nissan 300ZX forum - Re: Re: Bad misfire, hunting idle, no high idle on cold start up
Subject Re: Re: Bad misfire, hunting idle, no high idle on cold start up
Posted by ttz'in (NorCal) on October 16, 2014 at 1:54 AM
  This message has been viewed 358 times.
In Reply To Re: Bad misfire, hunting idle, no high idle on cold start up posted by Sportzcoop on October 15, 2014 at 10:48 PM
Message For bad idle disconnect coil connectors one at a time, idle should drop. Reconnect, go to next connector.
If idle doesn't change, you've found the cylinder causing a problem.
Sure, non oem sensor, or connector could be an issue.
Could also be ECU related. Also had a MF on #3.
Had continuity in new EFI harness #3 ground wire from FI connector to ECU plug, so that was good.
Turned out ECU was not sending ground signal to #3.
Ran jumper wire from #3 injector connector ground wire to #2 injector ground wire.
Problem solved. Bad ECU driver.
