TwinTurbo.NET: Nissan 300ZX forum - Re: I would do a power balance test to determine if it is one
Hydrus (Dallas)
on October 15, 2014 at 9:37 PM
posted by SammybTT(TN)
on October 15, 2014 at 09:29 PM
Seems like multiple since its missing out of both exhaust. The driverside is worse than the passengers.
Bad misfire, hunting idle, no high idle on cold start up
Hydrus (Dallas)
13:08:18 10/15/14
Check water temp sensor, correct NGK plugs ? (n/m)
ttz'in (NorCal)
13:40:40 10/15/14
Replaced coolant temp for ECU and put fresh ngk iridium in.
Hydrus (Dallas)
13:42:11 10/15/14
Is misfire only one cylinder ? (n/m)
ttz'in (NorCal)
14:49:25 10/15/14
SammybTT(TN)
21:29:07 10/15/14
I replaced it with an autozone one. Picking an oem one up at
Hydrus (Dallas)
21:35:51 10/15/14
Re: I would do a power balance test to determine if it is one -
Hydrus (Dallas)
21:37:19 10/15/14
Re: Bad misfire, hunting idle, no high idle on cold start up
Sportzcoop
22:48:31 10/15/14
Re: Re: Bad misfire, hunting idle, no high idle on cold start up
ttz'in (NorCal)
01:54:55 10/16/14
First item is power balance test (n/m)
SammybTT(TN)
12:46:40 10/16/14
Sorry shouldve made a list of everything ive done.
Hydrus (Dallas)
18:41:16 10/16/14
What were the results of the power balance test...?
-Grimm-
09:57:07 10/17/14
All cyclinders are firing and misfires continue.
Hydrus (Dallas)
12:41:26 10/17/14
Misfires at idle?
-Grimm-
17:23:04 10/17/14
Re: Misfires at idle?
Sportzcoop
23:18:50 10/17/14
They were on idle and under load. I knew it wasnt my injecto
Hydrus (Dallas)
17:26:57 10/18/14
