TwinTurbo.NET: Nissan 300ZX forum - sounds like a vacuum leak. As for timing it is set at >>
Subject sounds like a vacuum leak. As for timing it is set at >>
Posted by ZUL8TR on October 14, 2014 at 3:05 AM
  This message has been viewed 257 times.
In Reply To Master Z mechanics please help. posted by sdvdoc on October 13, 2014 at 09:46 PM
Message idle which you can't achieve, at 2500 the timing degrees would be higher. Did you make sure of the timing belt position on the cams and crank? You might be couple of cogs off? Put engine piston #1 at TDC of compression stroke (crank index mark should be lined up) and see where the cam index marks are relative to the block marks.
ZUL8TR in Orlando,FL
