TwinTurbo.NET: Nissan 300ZX forum - SUCCESS! from Fustrated Clutch bleeder in Atlanta
Subject SUCCESS! from Fustrated Clutch bleeder in Atlanta
Posted by jgbatlantaZ on October 12, 2014 at 7:48 PM
  This message has been viewed 222 times.
Message Well, it took using Speed Bleeders at the Slave cylinder and Fender line, also manually pumping the slave cylinder to move the air out of it. BUT, I swear the big difference was bleeding the system with the car running!
For some reason, results with the engine off were mediocre at best, with a mushy pedal, and clutch engagement only 1mm from the floor the best I could achieve.
With the engine running, the system was successfully bled in about 5 minutes! Go figure! It seemed to push a lot more hydraulic fluid a lot faster that way.
Any explanations? How does the clutch power booster/engine running enter into the picture? (If at all).
I'm just happy it all finally worked out and the car is drivable again......although I missed the Z nationals at Z1 this weekend because of all this. :(
