TwinTurbo.NET: Nissan 300ZX forum - Not necessarily
Subject Not necessarily
Posted by Zxpress on October 11, 2014 at 11:45 AM
  This message has been viewed 182 times.
In Reply To Will a new speed sensor fix my speedometer ? posted by Devonz32 on October 10, 2014 at 09:30 PM
Message Speed sensor seems to be the first component people jump to. Another common cause is a corroded contact plate, or broken solder on pins in the cluster. There are some good repair write ups. Just have to search. Also, before you buy a new speed sensor, ohm test the one you have. I don't have the spec, but like most everything else on the z32, it can be tested before you piss away money.
