TwinTurbo.NET: Nissan 300ZX forum - Re: How high did you pressurize on boost leak?
Subject Re: How high did you pressurize on boost leak?
Posted by madkiwi on October 10, 2014 at 5:14 PM
  This message has been viewed 308 times.
In Reply To How high did you pressurize on boost leak? posted by ttsmokin on October 10, 2014 at 02:16 PM
Message The most I pressurized to was 4 psi. It just popped out, every time. I figured it was a little loose fitting... and it does not do that while driving.
Clogged/screwy injectors is what I am hoping to rectify by running the Redline Si-1 through.
I was going to get the Knockspy program, but my Consult reader was defective, so I had to send it back to the Ebay seller. It would not read the mph, it would cause a HICAS error code and it put the car into "high speed steering" mode- with reduced power assist on the steering. All very disconcerting, had to shut down and restart to make the error code go away and the power assist come back.
I am looking for a new reader, I guess the best bet is to get one of the serial port versions, and use a serial to USB cable (the one I had was an actual USB tool).
