TwinTurbo.NET: Nissan 300ZX forum - How high did you pressurize on boost leak?
Subject How high did you pressurize on boost leak?
Posted by ttsmokin on October 10, 2014 at 2:16 PM
  This message has been viewed 322 times.
In Reply To Car runs rich, goes into safety boost posted by madkiwi on October 10, 2014 at 12:14 PM
Message It is not normal for the dipstick to pop out. Does it do this under normal driving conditions?
It would be interesting to know your AFRs if you had a wideband available to use. It is possible that while your fuel pressure is OK and the injector coils OHM properly that they may not be spraying properly. Potentially clogged or poor spray pattern.
I can't comment on the MAF readings.
I replied to your earlier thread and recommended you use the KnockSpy program to detect the conditions that you are going into safety boost. It would be a big help diagnosing your issue.
http://www.zromtech.com/products.aspx?productid=1
