TwinTurbo.NET: Nissan 300ZX forum - Either injector should work fine.
TriniTT
on October 10, 2014 at 11:08 AM
Re: Like I said before, the adapter is designed to be identical
posted by Kvert
on October 09, 2014 at 07:27 PM
The cap around the pintle cap shouldn't matter, but the lower oring should be pressed firmly against the adapter to create a tight seal.
Cheers,
JBrobst
Z1 injector adapter kit
Kvert
18:34:39 10/03/14
Update
Kvert
19:20:10 10/03/14
Same problem kris. New style injectors in OS rail.
ttz'in (NorCal)
03:18:38 10/04/14
Re: Same problem kris. New style injectors in OS rail.
WazTTed
03:22:51 10/04/14
Thanks Simon. I believe that's what Bernie uses in his
ttz'in (NorCal)
03:36:02 10/04/14
Kvert
07:58:11 10/04/14
Re: Re: Same problem kris. New style injectors in OS rail.
ttz'in (NorCal)
11:12:00 10/04/14
Installer error. (n/m)
TriniTT
11:20:51 10/08/14
No problems with CZP's injector adapter kit (n/m)
ThisIsSparTTa
10:06:27 10/04/14
Sounds to me like you're missing pintle caps.
TriniTT
15:33:55 10/07/14
Re: Sounds to me like you're missing pintle caps.
Kvert
16:07:31 10/07/14
Pintle caps should be nice and tight.
TriniTT
16:47:48 10/07/14
Re: Pintle caps should be nice and tight.
Kvert
18:19:13 10/07/14
The jwt kit isn't functionally different than the z1 kit.
TriniTT
19:39:02 10/07/14
Re: The jwt kit isn't functionally different than the z1 kit.
Kvert
21:00:50 10/08/14
The adapters are designed to be the same shape as the newer
TriniTT
22:27:47 10/08/14
Kvert
22:29:21 10/08/14
TriniTT
07:27:12 10/09/14
Kvert
19:27:12 10/09/14
Either injector should work fine. -
TriniTT
11:08:18 10/10/14
Re: Either injector should work fine.
Kvert
15:02:45 10/11/14
Great! Glad you got it figured out, that's the sole purpose
TriniTT
14:53:02 10/15/14
Weird. I have the JWT Kit which the Z1 is similar to and
ZXRider
18:27:16 10/08/14
