TwinTurbo.NET: Nissan 300ZX forum - Re: Like I said before, the adapter is designed to be identical
Subject Re: Like I said before, the adapter is designed to be identical
Posted by Kvert on October 09, 2014 at 7:27 PM
  This message has been viewed 353 times.
In Reply To Like I said before, the adapter is designed to be identical posted by TriniTT on October 09, 2014 at 07:27 AM
Message I may have found my issue. When I do a search for z32 injector images I get 2 types. One with the screens in the middle and ones with the screens near the base close to the lower oring. I have the type with the screens in the middle, which appear to be j30 injectors. With the adapters on and a tight cap installed, there is a sizable gap between the bottom of the adapter and injector cap. Is this normal or should they be touching? If the cap is what holds the oring in, I would think this gap is a bad thing. The gap is about 2-3 mm eyeballing it.
