TwinTurbo.NET: Nissan 300ZX forum - The adapters are designed to be the same shape as the newer
Subject The adapters are designed to be the same shape as the newer
Posted by TriniTT on October 08, 2014 at 10:27 PM
  This message has been viewed 292 times.
In Reply To Re: The jwt kit isn't functionally different than the z1 kit. posted by Kvert on October 08, 2014 at 09:00 PM
Message style fuel rails with regard to how the injectors fit into them. That's why I say the issue isn't the adapters, because the issue you're having would be happening with any of the available adapters or a newer style rail. I know I keep saying it, but the pintle caps shouldn't be able to come off without a lot of force, not without pliers or something of the sort. So if they came off on their own, there's an issue with them. I wouldn't install any injectors without using new caps because they are necessary to create a lip for the lower oring to hang onto. If the pintle caps are on tight as they should be, they won't come off and your orings will maintain a nice tight seal.
Cheers,
JBrobst
