TwinTurbo.NET: Nissan 300ZX forum - Re: That seems like too much oil leaking for it to be the pan
Subject Re: That seems like too much oil leaking for it to be the pan
Posted by MaxxAction on October 06, 2014 at 11:36 AM
  This message has been viewed 384 times.
In Reply To That seems like too much oil leaking for it to be the pan posted by Woody75 (Denver) on October 06, 2014 at 09:15 AM
Message Absolutely...
way too much oil to be coming out of the pan unless it is overfilled by about two quarts, or leaking out of the pan itself (a hole in the bottom surface). Check your front main, the banjo bolt that holds the oil feed for the DS turbo into the block, and the oil pump gasket.
