TwinTurbo.NET: Nissan 300ZX forum - A few more things to do
Subject A few more things to do
Posted by jerdobi on October 04, 2014 at 6:10 PM
  This message has been viewed 213 times.
In Reply To Engine lost power/runs weird posted by ukrdon2006 on September 29, 2014 at 10:51 PM
Message Switch the coil packs between 1 & 2 see if it moves to cylinder 2. If not pull plug from cylinder 1 after running and use flashlight to see if its wet with fuel or dry. If dry, most likely the injector is bad and not opening. If wet, it's a seal leak on the injector. At least cylinder 1 is easy to get the injector out.
