TwinTurbo.NET: Nissan 300ZX forum - I've experienced oil temps about 15-20 degrees higher
Subject I've experienced oil temps about 15-20 degrees higher
Posted by ttz'in (NorCal) on October 03, 2014 at 2:04 PM
  This message has been viewed 316 times.
In Reply To Oil Temperature Help posted by Slash300zx on October 03, 2014 at 01:00 PM
Message than water temps under normal conditions, which it appears you are seeing also.
Over 300 for an hour or so you would probably be taking the motor out again, not asking about it.
Think your trick Glowshift gauge is having issues.
Not sure, but couldn't you have T'ed off the pressure sensor for temp sensor and not used the adapter plate?
