TwinTurbo.NET: Nissan 300ZX forum - Re: Engine lost power/runs weird
Subject Re: Engine lost power/runs weird
Posted by ThisIsSparTTa on September 30, 2014 at 9:05 AM
  This message has been viewed 326 times.
In Reply To Engine lost power/runs weird posted by ukrdon2006 on September 29, 2014 at 10:51 PM
Message -Perform a power balance to test to see if 1 or more cylinders are missing.
-Pull codes from the ECU, not all codes result in lights.
-Check your TPS
-Check your MAF
-Check your timing
-Check your fuel pressure
-You have a 91, have you replaced your fuel injectors with new style or performed the switched voltage mod?
[ http://z32.wikispaces.com ] will help with a lot of that
