TwinTurbo.NET: Nissan 300ZX forum - More common for plastic end tanks to leak (ie OEM setup)
Subject More common for plastic end tanks to leak (ie OEM setup)
Posted by ZXoltan on September 29, 2014 at 4:43 PM
  This message has been viewed 262 times.
In Reply To Koyo Aluminum Radiator Leak. posted by ZXRider on September 29, 2014 at 01:30 PM
Message The aluminum radiators generally only leak in this area when there are faulty welds or the parts have corroded thru. Welds should be corrected fairly easily, but if its due to corrosion, then better off to toss it. If it has corroded through in such a short time period, better find out why so you dont ruin the next one...
