TwinTurbo.NET: Nissan 300ZX forum - I hope you're running the correct NGK plugs
Subject I hope you're running the correct NGK plugs
Posted by FrozTTy on September 29, 2014 at 11:11 AM
  This message has been viewed 184 times.
In Reply To Blue smoke. And unburnt fuel. What is it? posted by iamdan012 on September 28, 2014 at 06:40 PM
Message Also, check their gap to make sure they're correct.
Change the engine temp sensor as well - easy as heck to change and it's only $20. This will give you comfort that it's at least working.
Do the 'heated oxygen sensor' test, make sure they're working properly.
A compression test wouldn't hurt either.
