TwinTurbo.NET: Nissan 300ZX forum - it could be the heads
wickdGSXR
on September 29, 2014 at 9:50 AM
Blue smoke. And unburnt fuel. What is it?
posted by iamdan012
on September 28, 2014 at 06:40 PM
Worn seals or valve guides. Oil sucking into the the lower plenum and being burned. If the car doesn't have full power, that could also be a valve problem. Unfortunately, if you go that deep...you may as well put in new rings and bearings. ?
iamdan012
18:40:05 09/28/14
Where are you located? :)
-Grimm-
19:39:47 09/28/14
Re: Where are you located? :)
iamdan012
20:15:12 09/28/14
Darn, too far to trailer it back to CA
-Grimm-
09:55:25 09/29/14
it could be the heads -
wickdGSXR
09:50:17 09/29/14
I hope you're running the correct NGK plugs
FrozTTy
11:11:06 09/29/14
