TwinTurbo.NET: Nissan 300ZX forum - Wow! Holy major failure Batman. I have never heard that >>>
Subject Wow! Holy major failure Batman. I have never heard that >>>
Posted by ZUL8TR on September 28, 2014 at 4:20 PM
  This message has been viewed 308 times.
In Reply To Car seems slow, weird lights are on and power steerings out posted by Devonz32 on September 28, 2014 at 11:14 AM
Message happening to all those at once. Suggest disconnecting the battery for a bit. As for the coolant it sounds like an overheat issue and discharge is overflowing the coolant tank bleed hole. Did you check the level in the overflow bottle? As for the PS look into the belt and see if it is slipping. Make sure you only add the correct fluid and it is not power steering fluid but auto tranny fluid, look in your manual for the specific type.
ZUL8TR in Orlando,FL
