TwinTurbo.NET: Nissan 300ZX forum - Sounds like you pinched an injector o-ring
Subject Sounds like you pinched an injector o-ring
Posted by ttsmokin on September 25, 2014 at 10:02 PM
  This message has been viewed 350 times.
In Reply To Really rich posted by 1995z32tt on September 25, 2014 at 06:38 PM
Message I would not run the Z any more until you find the leak or you could hydrolock your engine and bend a rod.
Pull the injectors back out and inspect the o-rings. You probably did not use enough lube or correct technique to install them.
