TwinTurbo.NET: Nissan 300ZX forum - Re: Could be a bad fuel pump
Subject Re: Could be a bad fuel pump
Posted by ZTom on September 23, 2014 at 10:16 PM
  This message has been viewed 192 times.
In Reply To Car shuts off when it reaches operating temperature. posted by Android300zx on September 23, 2014 at 09:46 PM
Message Start the car and let it shut off on its own then carefully remove the fuel hose after the fuel filter put a rag underneath to catch fuel dripping out. Have a helper attempt to start the car while you look to see if fuel is coming out. I suggest you use a clear plastic bottle and insert the fuel hose while the helper attempt to start the car. If no fuel come out then that's your problem. Replace the fuel pump.
