TwinTurbo.NET: Nissan 300ZX forum - Car shuts off when it reaches operating temperature.
Subject Car shuts off when it reaches operating temperature.
Posted by Android300zx on September 23, 2014 at 9:46 PM
  This message has been viewed 198 times.
Message Car starts up fine when cold but when it reaches operating temperature it turns off. If you try and turn it on again it just cranks but doesn't turn back on until the engine gets cold. What could be the possible issues?
Now I replaced the Coolant Temp Sensor and the one next to it with new OEM from Z1. The car also smokes from the exhaust on start up. Car is on CT right now and I live in NJ. My buddy is looking the car over and was going to drive it to NJ last Saturday when it cut off on him when he filled it up with gas.
Feel free to ask questions and I'll answer as soon as I can. Thanks!
Car is a 1990 300ZX NA
Backstory:
Bought this car almost 2 years ago and have been working on this very long/annoying/stressful project. I replaced/upgraded the following:
120K performed and timing set.
Aftermarket eBay Headers
Stock Cats
HKS Exhaust
Rebuilt MT Transmission
5SPD NA ECU (stock)
Converted to New Style 270CC injectors
Replaced Fuel Pump
Silicone PCV hoses
Deleted Carbon Canister
Relocated Power Steering
Replaced all fuel lines
Brand new EFI harness w/ 12V mod and PTU subharness mod
Deleted Coolant Lines under Plenum
AIV Delete
Replaced O2 sensors
Completed 5SPD swap
Brand New Clutch Cylinder
Brand New SS Clutch Line
Z1 E-Fan
Wired Thermostatic Switch
Brand New OEM Radiator
Relocated Fuse Box under Headlight
New Silicone Overflow Hose
New Silicone Brake Booster Hoses
New Silicone Heater Core Hoses
New OEM PS High Pressure Hose
New BMC brace
New Z1 Exhaust Gaskets
New OEM Rear Main Seal
Resealed Oil Pan
New OEM Coolant Temp Sensor and Spade Sensor (on hard pipe)
