TwinTurbo.NET: Nissan 300ZX forum - Sounds like pinion bearing is shot (n/m)
BarryGZX
on September 22, 2014 at 12:49 AM
Axles disconnected, its definitely just the diff grinding
posted by ThisIsSparTTa
on September 19, 2014 at 10:54 PM
Rear end noise
ThisIsSparTTa
20:06:31 09/18/14
Re: Rear end noise
ZTom
23:07:22 09/18/14
A small amount
ThisIsSparTTa
08:34:16 09/19/14
I had my diff off two days ago..spun by hand
wickdGSXR
00:04:41 09/19/14
I may have to
ThisIsSparTTa
08:36:48 09/19/14
what about the heat shields at the rotors? (n/m)
aliaZ
09:29:05 09/19/14
Rotors and driveshaft are off, still makes noise. (n/m)
ThisIsSparTTa
09:57:03 09/19/14
Re: Rotors and driveshaft are off, still makes noise.
ZTom
11:10:39 09/19/14
Tips for bad wheel bearing?
ThisIsSparTTa
12:12:10 09/19/14
Wheel bearing would be better than a diff rebuild
-Grimm-
13:23:11 09/19/14
Re: spin the wheel if it make grinding noise then
ZTom
13:31:57 09/19/14
glad you found it. I ordered bearings today
wickdGSXR
15:38:30 09/19/14
Re: glad you found it. I ordered bearings today
ZTom
20:31:10 09/19/14
ThisIsSparTTa
22:54:12 09/19/14
Sounds like pinion bearing is shot (n/m) -
BarryGZX
00:49:16 09/22/14
