TwinTurbo.NET: Nissan 300ZX forum - The clutch switch signal runs to the hicas module.
Subject The clutch switch signal runs to the hicas module.
Posted by Evan_Wright (Ca) on September 18, 2014 at 12:47 PM
  This message has been viewed 456 times.
In Reply To Clutch switch wire access posted by SammybTT(TN) on September 17, 2014 at 07:05 PM
Message In older z's with hydraulic hicas the module is next to the ecu. I believe the z's with electronic hicas have their module mounted behind the drivers seat which would be less convenient then just tapping at the switch itself.
Here's a writeup I made a while back that might help. Some of it is specific to that particular device but I believe the clutch switch info you need is applicable.
[ http://www.300zxclub.com/showthread.php?t=184916&highlight=Wot+box ]
