TwinTurbo.NET: Nissan 300ZX forum - Clutch switch wire access
Subject Clutch switch wire access
Posted by SammybTT(TN) on September 17, 2014 at 7:05 PM
  This message has been viewed 313 times.
Message I tried to access the clutch switch wire for installation of my 2 step launch controller and didn't have much luck. I did tap into it at the cruise control module that is located under the ECU but that requires the cruise control to be onto function properly.
Question: where is the easiest access to the clutch switch wire? Is there some location the wire runs beside the actual switch? I have removed trim and stood on my head but no luck getting to the switch. Any suggestions would be appreciated
Cheers
