TwinTurbo.NET: Nissan 300ZX forum - headgasket leak after 15min rebuild
Subject headgasket leak after 15min rebuild
Posted by Snake9289 on September 16, 2014 at 7:31 AM
  This message has been viewed 212 times.
Message So when i check the gasket i saw on no.6 cyl. A path between the two small collant hole like the flow was not enough and the collant make its way in the graphite of the gasket .... i will try to put a picture later so my question is that a symptome that i didnt torque enough ( bad calibrate torque) or its when i open the water jaket to get better flow into the no. 6 cyl. So now it to much flow for the litle hole in the gasket ?
