TwinTurbo.NET: Nissan 300ZX forum - no underdrive crank pulley
Subject no underdrive crank pulley
Posted by Z32CheekiBreeki on September 15, 2014 at 11:04 PM
  This message has been viewed 171 times.
In Reply To Do you have an underdrive crank pulley? posted by ttsmokin on September 15, 2014 at 02:06 PM
Message Nope, she's all stock (at least under the hood)
I'm leaning towards the fact that it's the alternator, but ill go ahead and clean the IACV for good measure like mentioned.
Is there a way to test the alternator specifically? Though I believe either the bearing is going bad or the belt is too loose/tight so I'm not sure how you could test that best checking tension on the belt
