TwinTurbo.NET: Nissan 300ZX forum - Re: Boost problems/leak
Subject Re: Boost problems/leak
Posted by MaxxAction on September 15, 2014 at 10:11 AM
  This message has been viewed 222 times.
In Reply To Boost problems/leak posted by cassi8u99 on September 15, 2014 at 07:52 AM
Message The intake pipes are routed to the valve covers, so pulling the oil cap is going to do exactly what you described.
A leak that big is probably a break in the accordion pipes. The pipe that connects the inlet pipes of the turbo to the air box/air filters. It is fairly common as the plastic they are made of dries and splits over time.
It would also likely cause what you describe because with a split in one of those pipes, the car is drawing an immense amount of un-metered air, confusing the ECU.
It is a pain in the butt, but you can test each section of piping independently and locate your leak.
