TwinTurbo.NET: Nissan 300ZX forum - Boost problems/leak
Subject Boost problems/leak
Posted by cassi8u99 on September 15, 2014 at 7:52 AM
  This message has been viewed 225 times.
Message Car info: My car has been sitting too much and this spring when I took it out for a drive it noticed this issue. The car has a boost controller and blow off valves otherwise is mostly stock.
Symptom: With the boost controller off (7psi) boost builds normally until 7 psi then the engine backfires and bogs. The symptom is the same at every other setting, pulls good until it reaches the point that it should open the wastegates.
Steps I have already taken: I tried to do a boost leak test and found that the air leaks out faster than I can put it in. I pulled the oil fill cap and I hear the air leaking in that area and no where else. I pulled the lines to the wastegates and checked that they open properly and the lines are tight. Also checked and tightened all intake bolts.
The only thing I can figure is the PCV valves are stuck? I would appreciate any diagnostic steps I can take to isolate the problem.
Thanks in advance
