TwinTurbo.NET: Nissan 300ZX forum - Installed short throw shifter, missing 5th gear shortly. Pt2
Subject Installed short throw shifter, missing 5th gear shortly. Pt2
Posted by XTZ on September 13, 2014 at 1:59 PM
  This message has been viewed 357 times.
Message Here is the foloow-up to my old post about the short throw shifter issue.. seen here: Clicky
Well, I uninstalled the short throw shifter yesterday, and now I can go into 5th gear. This is very strange, as it seemed to go into 5th when I installed it, and then one day it popped out while driving under normal conditions. Then after, it would not go into 5th. I even tested this by loosening the main bottom plate so I could push the shifter as far forward as possible. No go; so I re-installed the OEM shifter, and it goes into 5th, but it does seem to have to be pushed forward more than ususal.. I've installed a short throw before, and had no issues. It's a no brainer to install.
I have a 98 spec transmission with very low miles. What do you think the issue would be?
src="http://carphotos4.cardomain.com/images/0015/68/31/154
78613_large.jpg" width="420" height="265">
